nightlight beep no alarm sound
zo6om
hello 2 all
i have problem in beep sound
u now if remove engine key and forget to close switch for nightlight should be alarm beep sound 2 close light
my problem now it is no beep sound if forget ???
where the problem ?
also at open driver door or close no see open/close door led in rpm screen consol ??
i check driver door switch (black switch side door) it is working and i change with anther switch same no led door open ??
Let me take a shot at trying to translate this....
I'm having problems with the beep sounds.
You know how when you turn off the car and forget to shut off your lights it beeps to tell you that you forgot them?
My problem is, there is no beeping if I forget to turn off my lights...
Whats the problem?
Also my door open/close indicator light in the dash board is not working
(not too sure about this one) I checked the fuses(?) and they seem fine, and even though I switched the fuse the problem is still there....
Well, if you did check the fuses, then i dont know what to tell you, if you didnt, then check the fuses(just a guess)
