NGK Plug wires.
2003.5 Laser Blue MSP
Does anyone have these installed on their MSP?? Also what are your opinions on these. I think it would be a nice replacement over stock.
I have them....it only replaces the two wires....you have to buy the bosch coil-on plug adapters to replace the whole set.....found that out the hard way, then NGK's are just two wires
where did you get the bosch coil-on plug adapters? In your opinion was it worth it, and did the ngk wire set come ith 2 or 4 wires?? Thanks for your input I did not know that.
NGK came with 2 wires.....got the boots at Hi/Lo....now called O'reilly, some habits die hard.....it was worth it for me because I had a rip in one of the boots, so I was only running on 3 cylinders
if there's not a problem with your stock ones, then I wouldn't bother with upgrading them just yet.....other stuff to do first.
