ahh.... the local place did not have the ZFR5J-11 in stock.
YP5 Toronto said:ahh.... the local place did not have the ZFR5J-11 in stock.
i ordered mine today. The guy told me the stock NGK part # is 2975... not a car but it is what the look it up under in the NGK book.ARunto said:Does anyone know what car uses the ZFR7F-11 plugs as stock plugs? I hate it when I go to advance auto and they want to know what car the plugs are for and then when I tell them to try to find them they never can.
-Alan
Hey Linux,LinuxRacr said:Let's start hearing some reviews on the plugs once you have them in!
Woohoo! 10-12!paulmp3 said:I should be getting mine friday. I will tell when i get them.
I have been running 10-12psi latley, Should i go with the .30 gap or stay at .28 where i have been at.
been there... 10-12psi with the ZFR7F-11 with the gap as is.Little Beavis said:Woohoo! 10-12!
Feels good don't it? Let me know what you think of the plugs.
Great meeting you too Juan! That's pretty impressive what yall are doing over in SoCal. Keep it up! Those plugs are awesome!HiBoost TS said:Hey Linux,
It was great to meet you while you were here in So Cal. We are running the extended plugs gapped at .30 and are performing good. BTW we have the new rods and Lower Mazda compression pistons. Now we can run 17 psi with no detonation on 91 octane fuel with this combination of lower compression and Haltech E6X. Car feels faster than ever.(wiggle)
Today we were hitting 20 psi on 100 unleaded fuel and the plugs are good.
For lower boost levels there should not be a problem.
Juan
Hey YP5, where did you get the plugs from in T.O. ? And how much ?YP5 Toronto said:OK.... I picked up a set of
ZFR5F-11 (extended reach) And BKR5E-11
I need the "hotter" versions, as colds starts are more of an issue in Toronto. Plus I run 94 octane and lower compression, so I am not as concerened about detonation at 8psi.
Question.... the ZFR5F-11 and the ZFR5J-11...what is the difference?
12psi feels real nice, just cant hit full boost in wet condition..traction is a b****igdrasil said:been there... 10-12psi with the ZFR7F-11 with the gap as is.
Car runs smoother! Cold starts is better, boosting is just a bit more aggressive, well, I was able to go from 14.9 to 14.7 @ 7psi.
@10-12psi with an FMU, fuel delivery is not stable, sometimes it detonates, sometimes dont.
