Newbie needing datalog feedback
nostrazoomus
2008 MS3
I just did my first datalog since installing intercooler, downpipe, colder plugs and reflashing to stage 2 + tmic with the AP. Did all these upgrades at same time and ran easy for a 100 miles or so before turning her loose for some wot runs.
Would like you guy's feedback on 2nd thru 4th gear run attached. I think it looks pretty good with my limited knowledge as the kr is minimal and the ltft's look good.
What other parameters should I log?
Should the boost hold a little more?
As you can see I don't post much...but this site has been a great resource for helping me decide on upgrades and learning about this cool little car.
Thanks!!!
Numbers look good. I see your afr dipped to 9.7 at one point. Mine does that too on occasion. I'm not sure if thats a bad thing though, hopefully someone can chime in about that. What do the map notes say about your boost targets for your setup ? That should tell you if your boosting to where your supposed to. I bet she pulls like a sob !!
