new wheels
nobody
+29 offset is going to be tough, especially with a 9 inch wide wheel. I am running 7.5 inch wide 18s' with +48, and it is close. Good luck, hope they fit, they are sweet...:) :)
s*** i didnt see that at first
29 no ******* way without a body kit
mine are 38mm and i have to cut the wells.
holy s*** good luck
im sure they will look good once the mods are made
nice thats what im ordering this week!
good move:D
s*** they are going to look gooooooooddddddd!!
damn i need new wheels:(
I have a question
Okay, so you bought the DG kit. Do you really have the ability to put wider wheels on the car, or are the factory fenders under the DG kit going to still restrict you as if you never bought the kit? Are you going to have to alter your factory fenders in order to fit wider wheels? Please post pics as I'm very interested in purchasing the DG kit. $450, that's awesome!
Thanks
i looked into this before i decided on a kit also.
the dg kit will allow 9 inch wheels with the prope offset. now whether or not 29 is going to fit he will find out. but when i put my 38 mm on it does require CUTTING the fenders ONLY if you are going to lower it.
since i did 1.5 " then i had to cut them. i am just waiting to order the kit this week.
the wings west one was also an option but after further investigation it reqiures the lip from the factory fender to stick on
it isnt really a wide body flare like the dg.
I've trim both the factory & the DG fenders, I'm still waiting for tires. I'm running the Toyo RA-1 225-40-18:)
When you're done...
Give us some info on how you installed everything. I can't wait to see your car!
Interesting. Have we met? lol. ARe you going to IAS at the end of the month. Real quick though. What's the point of putting such a wide wheel on there? Unless you go boost. lol.
But still might make that car push in the turns with such a wide wheel in the rear.
Rishie
