AequitasVeritas
- 2007 Mazdaspeed3
well, on my Hypertech, which I am running, I can go +/- 500rpm on the rev limit. As for CARB, it is removable if needed. I do not believe they have CARB exeption.
This is also why they are so lean. They cannot make files that will allow you, the end user to make your car dirty so to speak.
( I presume you are running a MS3, right?)
#3, no, its a simple rewrite.
and for fasteract, yes I have a 2007 Mazdaspeed3 and it is daily driven by me.
Chris, thanks for the detailed information. I look forward to one of our members being able to post some independent datalogs through Dash Hawk, etc., on a Hypertech programmed MS3.
I do think that 17-18 psi sustained boost is safe provided that AFR's stay on the rich side and provided that the turbo does not see sustained operation above 5,800-6,000 rpm. That center shaft on the K04 turbo is only 4mm in size. The K04 is notorious for shaft failure due to excessive heat when it is operated at high boost conditions where the engine is running over 5,800 rpm. You cite the reason correctly -- that little (but responsive) turbo simply turns into a heat engine and EGT's kill the shaft, and accordingly the turbo when it is pushed outside its thermal efficiency range.
VW and Audi guys running the K04 have seen their tuners and turbo mod guys installing a separate EGT sensor directly on the turbo housing to keep an eye on that. Aftermarket supplier of K04's for upgrades on those cars are very careful to point out that the turbo cannot withstand turbo housing temps above 875 degrees C. (1600 degrees F.) On their turbos based on the engine flow characteristics of those cars, that temp is reached at 5,800 rpm and 15 psi boost. The result may be different on our larger displacement engine and slightly different K04. I simply do not know.
I'm sure you guys will take turbo life into consideration with your tunes.
I found your observations about aftermarket intakes very consistent with what we have all discovered on this board. There is a huge restriction in air flow through the stock air box. I did not realize that aftermarket intakes actually raise boost about one pound, but your observations make sense to me and I appreciate learning this.
Our stock exhaust is also very restrictive, but not from the CBE. The restriction is upstream in the downpipe and midpipe. Those of us who have corrected this with aftermarket downpipe and midpipe or racepipe (catted or catless) are seeing further boost increases so that it is not unusual for us to see 17-18 psi on a mechanical boost gauge with nothing more than a good intake and dp/rp mod.
I don't know if there is interest in taking aftermarket dp's into account as a tuning option, but I throw it out as a suggestion.
You guys are really putting in some serious R&D. This is helping me lower some initial skepticism that I have about all new products.
As you have also probably become quite aware, the stock ECU is very aggressive about slapping us with fuel cut when we get to 17 psi under load, especially when the weather is cold. That is a good thing to protect the engine. We (well, at least I) do not want to lose that protection, but would like to see a solution that raises the load limit just a tiny bit to allow for 17-18 psi boost, while still slapping us down with fuel cut above 18. Again, this is premised on the assumption that this can be done safely.
Sorry for my lenghty "wish list." Welcome to our little corner of the automotive world. I look forward to learning more about your product and any optional tunes you are considering.
Chris @Hypertech...could you add a Cobb SRI (short ram intake) to your intake options. This one is probably 1 or 2 in popularity as an aftermarket intake.
Have installed the Hypertech programmer and initial impression is very good. I initially had a Cobb AP with a Stage 1 tune since I plan on this DD of mine to stay stock other than an intake and better (Forge) BPV. Wasn't that impressed with performance gain and sold it. Someone with the need for a custom tune could probably get their monies' worth out of it more than I. The Hypertech however is definitely providing a lot much punch in the low to midrange...
Hi Chris, thanks for the info, but a few questions;
1 what did you change to get to this whopping 250 number?
2 where are the afr sheets?
3 are you able to control all the base maps, or are you simply changing calibration files
