wait...its not the cams...its the cam gears, right? Use the MSP cams, with MSP cam gears...with the 626 engine and head...you could use the 626 cams, but they're probably the older even more mild grinds used in the 118hp FS engines...but either way, the cam gears are the important part...the MSP ecu can't read the 626 cam gears properly...Also, are you using the MSP's cam position sensor? I'm not sure which 626 engine you have...some 626's did not have a cam position sensor in the same location as the MSP's...the cam position sensor has to be mounted on the exhaust cam gear (on the valve cover)...if your 626 engine doesn't have a sensor hole in that spot, swap the valve cover from the MSP engine over...a cam position sensor in any other area won't work with the MSP ecu...
So just to clarify, as this sort of confused me...you should be using your MSP cams (if they are in good shape), MSP cam gears, MSP cam position sensor and the MSP valve cover...unless the 626 valve cover has the sensor hole in the same location...its the 626 car your engine came from that determines all this stuff...i know you said 2001 626, but if you got the engine from a wrecker...that info may not be accurate...
lastly...as it wasn't pointed out, but should be ok...the crank position sensor and crank pulley should be from your MSP also...some 626 FS engines used an elipitical blade style crank pulley, instead of 'teeth' like the MSP...if they are identical, use either...but the MSP ecu and sensor won't read that crazy blade thing right, either...
if the MSP cam gears are shot or something, i have a bunch of extras laying around...
