What is the big deal with doing VTA or 50/50 instead of the normal recirc? Is it just for the cool sound VTA makes?
I think you might be missing the reason why most people swap the stocker out. If it is for the reason why most people swap, stocker is leaking, you need to know if it is or not via a boost gauge or a data log first. Then you can go about swapping it. Different BOVs make different sounds. Also, with the stock airbox you won't hear most of it unless you VTA because of the design.
Carlson's BOV (Forge) and mine (HKS) sound completely different from each other and they are both setup for recirc. Even the simple cheap one from a 1G DSM (Eclipse) sounds different and can be painted black to match stock.
Sorry Mark for crapping on your thread.
