Ive searched google and this forum for someone with the same problem as me but I havent found someone with the exact same problem. Its cranking but wont start. P0340 is indentified as a camshaft position sensor fault. Ive tested and replaced the sensor with no results. Some websites tell me that this code gets thrown out for various but semi related components. When the issue presented itself I was cruising down the highway in the fast lane and the engine cut out and it wouldnt start again.
Is it fuel relay, pcm, egr, crank sensor, or timing belt? I have no idea what to do next?! so far ive only tested and replaced sensor and cleaned and charged battery.
