Picked up a few new stuff. I plan to upgrade the sub and speakers to Rockford ones but I had these kickers sitting around. They don't sound too bad either.
-Jensen Nav VM9424 6.2-Inch with Bluetooth.
-Kicker 12 inch sub and enclosure.
-Kicker speakers Kicker DS65 6.5" Coax Speakers.
-Rockford Fosgate Prime R500 amp with base control.
I also built a shelf for about 20 bucks. It's ultra light plywood wrapped with black felt. There's 2 vertical planks to keep it steady and keep the base from moving. Also the Base blocks my trunk light so I put in an LED light on the shelf. I don't use my car to really carry anything since I have a F150 for that so having room is not a concern of mine.
Here's the Nav, I have a spare Iphone attached to it to be a music device. You can kind of see it off to the bottom, I have it mounted next to the glove box.
Here's the blutooth and base control
Here's the base and trunk space
Another angle. With the LED light and planks.
here's the amp, I attached it to the back of the enclosure box because it was too long to fit under my seat.
