New Rims
TAT2CHCK
So I found some rims that I happen to like, an older Konig rim that used to be on my friends Altima.
They are 19in and do did suprise me when I put them on the car, also raised it a little bit higher than it used to sit.
How many Mazda 3's have you seen with 19in rims ?
At this point no work is done to it to make it any faster so at this point I am not concerned about how it will change the handling, I am not going to be able to afford to do anything about its performance until early next year.
Just curious what your opinions are.
Get a little over-excited with that Submit Post button?
Handling and ride height will be affected more by the tire you choose. The only reason I would advise against riding 19's is that it really limits your options in terms of tire choice.
Depending on which model they are, it might slow your car down a miniscule amount due to an increase in unsprung weight. But this will be mostly negligible.
