Just bought a one-owner, 2001 Mazda Protege MP3 with 25k miles. Was a city car, so a bit dirty, but it'll clean up nicely. I've had 3 Miatas, needed something with a little practicality.
So I've been digging around this forum and have a few questions:
1. I have the Z828 head unit. Looking to take it out to install an aux-in until I settle on a new deck. Got the small, silver surround off. Then popped the dash surround off. Removed the two screws. I'm stuck there. Nothing budges. I tried wedging a screwdriver along the sides with no luck. Did some searches, found a lot of descriptions, but nothing really clear. Any hints?
2. Noticed the rear clunk during the test drive. Found a thread linking to the AXR kit. Am I good to go with just this, or should I also get new bushings? Change anything else while I'm down there?
3. Car is still riding on original rotors/pads. Saw a thread stating MS6/MZ6 calipers/rotors bolt right up. From RockAuto, should this do it for the calipers?
2006 MAZDA 6 S 3.0L 2968cc V6 FI : Brake/Wheel Hub : Caliper
A-1 CARDONE Part # 18B5000 More Info {Unloaded; [Caliper w/Installation Hardware] Reman.}
Front Left; OE Metal Piston;Supplied w/Mounting Bracket
A-1 CARDONE Part # 18B5001 More Info {Unloaded; [Caliper w/Installation Hardware] Reman.}
Front Right; OE Metal Piston;Supplied w/Mounting Bracket
$89 each.
4. Stereo - are there any custom-fit boxes for the trunk? Couldn't find any on Crutchfield. Looking for something a little nicer than a bass tube.
Thanks in advance.
$89 each.
Thanks in advance.
