New MBC where to put in?
udrive2slow
in need of a ms protege
ok well i just got my MBC i wanna be safe with my boost so im taking my forged wastegate and setting it to its lowest setting (5psi) and then putting in the MBC and setting the boost... now the question comes in where do i place it?? i believe that i can place it in line with the wastegate vacume line as long as i have the correct side facing the wastegate?? if someone could verify or correct me id greatly appreciate it.
Yep. And if you haven't already, now is a good time to run a dedicated vac line to the WGA. 3 feet of 4mm (5/16") vac hose or fuel line is all you need.
And double check which port on the MBC goes to the wga and which goes to the vac source. If you get it backwards, you'll overboost.
In any case, roll into boost slowly on your first time out and watch the gauge.
