I am starting to build my 2000 ES for FSP. I have talked with a few of you guys about it already, but wanted to start a thread to get some info out there for others wanting to prepare a 99-00 Protege with the 1.8L.
I have owned the car since new in 2000, and I have raced in Stock for a few years, then STS a little. I then raced an RSX Type S for a few years, and have decided to go back to the Protege.
Since my car has 150K+ miles, I am doing a bit of preventative maintenance and performance upgrades at the same time.
My first stage is ordering up the AWR suspension with Bilsteins. I like the Bilsteins for the durability, acuracy, and the non adjustable shock will make tuning simpler (swaybars, tires, and alignment).
I have already pulled the tranny (with ALOT of help from a friend), and have dropped it off at OPM for the LSD treatment.
I've got the Fidenza flywheel, which is the first snag. The Fidenza Flywheel (I found this weekend) is not designed to fit the standard F-type pressure plate. I have found a pressure plate that I am told is designed specifically for this purpose, so I will let you guys know a little more once I know it works for sure.
Part of my maintenace has been replacing wheel bearings. I thought I had a bad lower ball joint, so I ordered new control arms (with new bushings). It turns out the new control arms look to have improved structure over the original parts that were on the car. Probably a change when they went to the 2.0L or Mazdaspeed models. In any case, it got me wondering what other suspension parts were beefed up (rear trailing arm???).
I also have my set of 14x8 Diamond Racing wheels which I am planning to get some Kumho V710 225-50-14's on.
I (with ALOT of help from a frined) am also doing some basic maintenance like replacing the timing belt, water pump, engine main seals. My goal is to have a decent running engine before I start to really mod it for power. I am shooting for my first event at the Dixie Tour on February 24/25. There are already some top notch competitors signed up. I'm not expecting to win at all, but see how much work will need to be done in order to realistically compete with the big boys.
By the time of the event I should have the suspension parts on (but not tuned), the LSD, flywheel and tranny overhauled, and the fresh set of tires.
Future plans are uping the horsepower with intake, ecu and exhaust...right now thats all bone stock!
