ok well my car currently only has a tbe fuel pump and i just put on the 3.5ets
First of all, HOLY s*** does this intercooler make a difference. With just the tbe and pump my car would hold 14-15psi, now i just went for a test run and datalogged a couple of things. Hello boost cut again. The car is spiking mid 19s and holding 17-18 before it cuts out, get back on it and the boost slowly rises to 17ish. A/f ratios are stupid rich, once again mroe proof the cpe standback leans the car out with everything zeroed out. i am hitting a/f ratios as low as 9.3 after the 1-2 shift. The hover around the mid 10s low 11s through the powerband, after boost cut hits, the a/f ratios stay right around 11 to mid 11s which is perfect and drop down to the 10s after k
Attached is a chart, 1-5th before i came up on traffic.
its hard to read, but be patient with it and youll understand it. my cobb intake will be here shortly, the intake alone raises the boost another 1-2 psi, so i strongly feel that you dont even need a mbc to hold 17-18with this car. just get a i/tbe/ic/fuel pump/map clamp and your good to go. anyway, enough bs, more data
