Are you sure you need one? (not trying to be a jerk, just asking) Did a mechanic tell you that, because I have seen several guys go looking for an ecu when they didn't need one. Check out car-part.com. You can get an ECU on there pretty cheap. Good luck.
ECU's VERY rarely fail. In fact, the only time I've seen it was because the car was in a flood and the ECU was submurged for about 3 days.
The one I have has 5MAB EEC-V MAZ-403 FSAR-18881 2ALU-12A650-DB *N7DACBPW6CRF* markings all on the bar code sticker on harness plug & 5MAB FSAR- NPEF 201311 on the smaller bar code sticker on the other end of it. Other than that it's just a silver flat box.
Thinking the 03 sportautos have FSBB-1881-C but doublecheck yours and let me know. If the FSAR-1881 is what you have now, you can have the one I have for shipping cost.
Oops, so I was looking over the notes my mechanic made on the invoice and he actually said the PCM might be the problem, not the ECU like I thought he said.
Since many have said that ECUs rarely go out, does that sound more probable that it could be the PCM or are those going out just as rare? Also, is it worse that it's the PCM than the ECU? (worse, as in more expensive to replace).
