Need Help
MAZSPEEDBOY
MSP Black Mica
I need a pipe that goes from the turbo to the intercooler because mine has sprung a leak and i dont wont to buy the full hardpipe kits. Does anyone know of a company that sells just this section. Not having boost sucks
What do you mean by "sprung a leak"? Did the hose come off or did it crack? The dealer should be able to replace the pipe for you. If not, then try a wrecker.
I mean it cracked where it connects to the diverter valve. And yes the dealership should but i rather have an after market piece
Well I just got back from the dealership and there going to cover it. I asked how much it would cost if it wasnt and he said just for the one section would be $315
If you do glue it, make sure the diverter hose is attached to the charge pipe. If not and you attach it, you run a good chance of cracking the epoxy.
Or I just didn't prep it right.
Either way, the dealer is pulling sime slick s*** on that. When they replaced mine, it was $180 for that charge pipe. Though they did cover it since they broke it.
Yep, mine broke there, too. I just used some Gorilla Glue on it and that held until I got my hardpipes.
