Need help!!!!!
msp727
ok so i have the ssafc and when i first get in boost it gor lean like at 17afr but then it goes to 10 now i can fix that but today when i went in to boost it went to 20afr and my car was sputtering bad so i don t know if thats the tune messing up or if it would be the turbo or wastegate
please help!!!!
You don't typically see vacuum leaks, you need soapy water or something wet to check for leaks.
or starting fluid. if you do it right, when you hit a vac leak, rpms should jump up
well i think its the tune cause the car only jumps lean ( 20afr) and 2.5 rpm and at like the lower vac and til 3 psi of boost other then that it runs normal
