Guys and Gals,
I have a Mazda Protege5 ATX 2002. I am in the process of changing my timing belt, water pump, serptine belts, and install a UDP. The thing holding me up is the crank pully bolt. I have a Craftsman electric impact wrench with 250 ft/lbs of torque. I have a regular Craftsman 3" extension and 21MM socket. The car is in park, passenger side up on a jack, jack holding up the engine (removed side motor mount) and the crank pulley is not spinning freely. I worked on the bolt for 30 seconds and got no where. The extension and socket are not moving, impact is spinning internally, and it feels like no work is being done. They spin just fine when not on the bolt.
I am just concerned because the crank pulley will not move. I'm also not using impact sockets and I'm afraid it's just spinning inside of the extension. Oh everything is 1/2" incase your wondering. I have the battery disconnected and concerned that I need to reconnect the battery to shift it do neutral to get the crank pulley to spin. Would connecting the battery at this stage cause issues? I need your guys help. Thanks again and yes I searched.
Magus
Magus
