Need Help on My Pro5
luditicks
aiight peepz i need help on dropping my car. . i am trying to drop my car but the nut on the linkage to the sway bar won't come out. and what it looks like its about to be stripped if i do more damaged to it and just in case imma grabe a new nut. . How would I take it out????
if you are just changing springs and keeping stock struts; you can keep the end links on and just change the springs. you just have to drop the rear sway bar on the rear.........the top of the front struts can get moved out of the wheel well with out much trouble.......
-R
im not sure what you are talking about exactly but if you are talking about what i think you are talking about, there should be a allen socket on the other end of that bolt you are trying to get the nut off of. stick an allen wrench in it and then back it off otherwise you are just turning the entire thing.
