I recently cleaned out my egr, MAF sensor and throttle body front and back hardly anything carbon build up. a/f ratios reading like 17.2 and cuts off reading (---) on and off when not in gear it used to read 14-5 - 15-5 used to hesitate also not as much anymore but i fell theres still a slight hesitate. ecu was flashed by owner before me i keep getting a fuel pressure regulator code and i replaced that thing twice oem FPR im lost i dont know what else to check for vacum on that is great it'll suck your face in. im planing on checking for a cracked manifold (steedspeed) one cuz i here a rattle when im a lil over -10 boost and up but i dont think that will set the a/f ratio that high will it? other then that this thing was well taking care of untill i got it i baby as much as i can do to money its a lil tough. here are my freeze frames my code is p0090 fuel pressure regulator control circuit.
DTC for which Freeze Frame was stored P0090
Fuel System 1 Status Closed Loop
Fuel System 2 Status Not Supported
Calculated Load Value 35.69 %
Engine Coolant Temperature 94 C
Short Term Fuel Trim - Bank 1 -3.91 %
Long Term Fuel Trim - Bank 1 10.16 %
Engine RPM 2092.75 rpm
Vehicle Speed Sensor 16 km/h
Ignition Timing Advance For #1 Cylinder 31.5
Intake Air Temperature 48 C
Air Flow Rate From Mass Air Flow Sensor 12.3 g/s
Absolute Throttle Position 18.82 %
