hello all, first timer here ... got these codes with the ForScan software, wondering if anyone has any experience? or is your advice to head directly to the shop
Also, is it worth subscribing to alldata.com or eautorepair.net to try to diagnose the issues myself? I have no issue tinkering with my car but of course I don't have any specialized tools that dealers/shops might have
===TCM DTC P0841:00-2C===
Code: P0841 - Transmission Fluid Pressure Sensor/Switch 'A' Circuit Range/Performance
Status (-2C):
- DTC Maturing - Intermittent at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Transmission Control Module
Freeze Frame #1:
-DTC: --- - DTC That Caused Required Snapshot Data Storage
-LOAD: 34.51 % - Calculated Load Value
-ECT: 68 °C - Engine coolant temperature
-RPM: 707 1/min - Engine Revolutions Per Minute
-VSS: 3.0 km/h - Vehicle Speed
-SPARKADV: 13.50 ° - Spark Advance
-IAT: 36 °C - Intake Air Temperature
-TP: 14.90 % - Throttle Position
-RUNTM: 230 s - Time Since Engine Start
-WARM_UPS: 254 - Number Of Warm-ups Since DTCs Cleared
-CLR_DIST: 1836.0 km - Distance since diagnostic trouble codes cleared
-VPWR: 13.85 V - Control Module Voltage
-APP_D: 8.24 % - Accelerator Pedal Position D
===END TCM DTC P0841:00-2C===
===PCM DTC P0442:00-AC===
Code: P0442 - EVAP System Leak Detected (small leak)
Status (-AC):
- Malfunction Indicator Lamp is On for this DTC
Module: Powertrain Control Module
Freeze Frame #1:
-FUELSYS: Closed Loop - Fuel System Status (Open/Closed Loop)
-LOAD: 33.33 % - Calculated Load Value
-ECT: 89 °C - Engine coolant temperature
-SHRTFT1: 0.00 % - Short term fuel trim 1
-LONGFT1: -2.34 % - Long term fuel trim 1
-MAP: 43.0 kPa - Manifold absolute pressure sensor
-RPM: 685 1/min - Engine Revolutions Per Minute
-VSS: 0.0 km/h - Vehicle Speed
-SPARKADV: 11.50 ° - Spark Advance
-IAT: 28 °C - Intake Air Temperature
-MAF: 4.40 g/s - Mass Air Flow
-TP: 14.51 % - Throttle Position
-RUNTM: 1171 s - Time Since Engine Start
-EGR_PCT: 0.00 % - Commanded EGR
-EVAP_PCT: 7.06 % - Commanded Evaporative Purge
-FLI: 42.35 % - Fuel Level
-CLR_DIST: 4173.0 km - Distance since diagnostic trouble codes cleared
-FTP: 0.1 kPa - Fuel Tank Pressure Transducer
-BARO: 100.0 kPa - Barometric pressure
-CATEMP11: 574 °C - Catalyst Temperature Bank 1, Sensor 1
-VPWR: 13.94 V - Control Module Voltage
-LOAD_ABS: 26.27 % - Absolute Load Value
-EQRAT11_CMD: 14.586 :1 - Commanded Equivalence Ratio (Air to Fuel Mixture) Bank 1
-TP_REL: 5.49 % - Relative Throttle Position
-AAT: 26 °C - Ambient Air Temperature
-TP_B: 14.51 % - Throttle Position Sensor 2
-APP_D: 7.84 % - Accelerator Pedal Position D
-APP_E: 8.24 % - Accelerator Pedal Position E
-TAC_PCT: 6.27 % - Commanded Throttle Actuator Control
-SHRTFT12: 0.00 % - Short Term Fuel Trim (Bank 1, Sensor 2)
-LONGFT12: 0.00 % - Long Term Fuel Trim (Bank 1, Sensor 2)
-ECT2_SUP: Yes - Engine Coolant Temperature Sensor 1 supported
-ECT1_SUP: Yes - Engine Coolant Temperature Sensor 1 supported
-ECT1: 89 °C - Engine Coolant Temperature Sensor 1
-ECT2: 46 °C - Engine Coolant Temperature Sensor 2
-ECT2: 46 °C - Engine Coolant Temperature 2 - Voltage
===END PCM DTC P0442:00-AC===
===OBDII DTC P0442-C===
Status (-43):
- Confirmed - malfunction is confirmed
Module: On Board Diagnostic II
===END OBDII DTC P0442-C===
Status (-2C):
Freeze Frame #1:
Status (-AC):
Freeze Frame #1:
Status (-43):
