Some of you already know, but I've started buying parts to turbo my car. Here's the spreadsheet I made of parts I need and costs of things new. If you see anything I need to add, let me know. If you see any good deals on anything on my list, let me know
Parts on the car
Things left to find/buy/steal
updated: 01/06/07
Parts on the car
- AWR Baffled Oil Pan
- Fidanza Flywheel
- Exedy Clutch
- Callaway Mazdaspeed Protege Exhaust Manifold
- Callaway Mazdaspeed Protege S-Pipe
- Turbohoses Hard Pipes
- Turbohoses SMIC
- INJEN Cold Air Intake
- Mazda Mazdaspeed Protege Radiator
- NSN Thermal Spacers (Intake Manifold/Throttle Body)
- Mazda Mazdaspeed Protege Bypass Valve
- Vibrant 3" Full Exhaust
- AEM Wideband O2 Gauge/Sensor
- Mazda Single Runner Intake Manifold
- Blitz SBC i-Color Sequenctial Boost Controller
- Defi Blue Racer Boost Gague
- Defi Blue Racer Exhaust Gas Temp Gauge
- Defi Blue Racer Oil Pressure Gauge
- Tochigi-Fuji Limited Slip Differential
- Garrett GT2864R Turbo
- Single DIN Triple Gauge Holder (see pictures)
- Apex'i Turbo Timer
- Mazda OEM Throttle Body Gasket
- Mazda OEM Exhaust Manifold Gasket
- Mazda OEM Turbo Flange Gasket
- Mazda OEM S-pipe Gasket
- Mazda OEM J-pipe Gasket
- Mazda OEM Exhuast Manifold Stud
- Mazda OEM Nut for S-pipe
- ATP Aluminum - Inlet Flange GT28R
- ATP Aluminum - Compressor Outlet Adapter GT28R
- Oil Lines and Fittings
- Water Lines and Fittings
- Slim Fans
- Mazda FS-ZE Intake Cam
- Vacuum Block
- Harness bar
- Cat-less side exhaust
- 1.8 coil pack
- GReddy Type-S Blow-off Valve ($125)
- GReddy BOV Flange - Steel ($35)
- GReddy BOV Flange - Aluminum ($15)
- Blitz SBC i-Color ($599)
updated: 01/06/07
