Marauder.45
- 06 MS6
let's see if this works
Does the AP merely increase the hp or does it also make the car feel smoother? My car's been somewhat sluggish after I upgraded the TMIC not sure exactly why. Probably gonna reset the ECU tomorrow and see if that helps.
How many miles did it take for your car to learn the flash? I loaded the same map and have about sixty miles driven so far.
Mine isn't done yet I guess, but it only flashed 4 times. 40 miles on it so far.
So nothing in the log I should be worried about? Everything running honkey dorey?
My car has taken as many as 185 miles to learn a flash. You can check to see if your car is finished learning it by turning the key On but not cranking the engine. After about 15 or so seconds, the check engine light will do one of two things: 1) Flash 8 times, 2) Stay on.
If it flashes 8 times, you're not done learning yet.
If it stays on, you're done learning the new map and you can let 'er rip.
Im calling shenanigans on this man. I only have 35 miles on mine since the flash, turned the key to the on position, let sit for almost a minute and nothing happens. Is there some form of documentation on this? From Cobb? From the manual?
