BlackCherry
- 2002 Mazda Protege 5
Around two rpm, for example a low rpm shift, or start up from first gear, causes some section of the exhaust pipe to touch somewhere, it sounds like it's below the rear seats, but it's hardly noticable from the outside, it's easily heard from the inside though, it started after i installed my corksport hangers. I have a RacingBeat
Between 2 and 3 rpm (2 1/2) something buzzes on the dashboard passenger side it becomes apparent as it hit's 2 1/2 then does down till it's no longer noticeable.
And finally when I put the fan on, it makes some kind of humming noise as if there something wrong with the passenger side fan. The higher of a number I go the more apparent it becomes.
I'm probably going to bring it to my mechanic, but I was curious if you guys had any input first
