vashthestampede
This is a dyno from my 90' Mazda Miata with the following mods.
1.6 stock motor - 50k miles
Greddy TD04-15G
Greddy manifold
Racing Mazda downpipe
Test pipe
Flyin Miata 2.25 dual cat back exhaust
Custom IC pipes
Starion IC
HKS SSQV
Hallman MBC
1.8 injectors
Vortech FMU
NGK extended plugs
Magnecor 8.5 wires
HKS foam filter
ACT extreme clutch
SS clutch line
Torsen LSD with 1.8 one piece axles
Simpson design short throw shifter
Emanage blue with pressure sensor, injector harness and main harness
Greddy full auto turbo timer
Greddy boost gauge
All fluids replaced with Redline synthetic
Last year I replaced the timing belt, waterpump, all seals, and other small maintenance items. Removed spare tire, jack, other small items in trunk. Full tank of gas and w/driver the car is under 2400lbs, couldnt be exact on a current number but will probably go down to 2300 this spring.
The following dyno slips and graph were from last year with the boost set at 8 psi spiking to 10-11 for a moment. The AFM cable kept coming loose at high revs and the HKS bov was causing false readings for manifold pressure. The dyno run is 1200rpms short of rev limit, so I could have expected some more power as the hp was still climbing.
After 22 pulls and a lot of tuning we gained over 40hp and 30lb-ft. The shop I went to had never tuned an Emanage but I had some idea of the support tool software so we got the hang of it.
Most issues are now fixed and I plan on doing more mods, fixing some other current issues, raising the boost to 15-16psi and doing a re-tune this spring. If I break the 250-260whp I will be quite happy. (thumb) The car now is roughly 1hp per 12lbs, if I break 250ish it will be 1hp per 9lbs. To give you an idea a new STI has 1hp per 11.5lbs. (poke)
Any comments or questions are welcomed (thumb)
Vash-
Greddy TD04-15G
Greddy manifold
Test pipe
Custom IC pipes
Starion IC
HKS SSQV
Hallman MBC
1.8 injectors
Vortech FMU
NGK extended plugs
Magnecor 8.5 wires
HKS foam filter
ACT extreme clutch
SS clutch line
Greddy boost gauge
Vash-
