Now that you mention it the car I test drove may have had the key still in the ignition.
Ok, update on the Door Lock Situation,
I have the Standard key (not Smart key)
With the key in the ignition, you cannot lock the doors using the all-lock button on the door panel, but you can individually lock each door
If you are inside the car with the doors shut and press all-lock on the door, the doors lock but the alarm is not armed. You can open the doors any way you want and the alarm will not go off
If you are inside the car with the doors open and press all-lock, then shut the doors, the alarm is armed. Opening the doors without the key will set off the alarm
If the doors are shut and you press lock on the remote, the alarm is set, and will go off if you open the doors without the key
