MSP Wiring Help
Zixxer
Honda S2000
Couple of wires were cut by the previous owner.
Any idea where these wires and sensor go?
I have a service manual, but figured I'd ask real quick.
May need better pics to identify them. The second two pictures look like grounds that attach to the driver's side of the cylinder head to a bracket. First picture doesn't look like an OEM sensor for a Mazda. Did the car have a standalone EMS?
Thanks for the help, I'll get some better pics. Car has a unichip.
Both wires come from the same harness, hopefully someone can help. I have a service manual coming this week.
The wire with the plastic cover over the terminal in the second picture appears to be the plug for the pressure sensor on the power steering pump, the loom on the wires isn't factory though so it's hard to tell where the wires should be. That wire should run to the passenger side and plug into the pump, not the driver's side near the battery.
Thanks! Yeah, I've noticed that alot of wire looms are cut and wires are run all over the place! I bet the motors been out.
