We didn't as the flow bench arrived when my head was already done.. I wasn't worried about the overall improvement as simply put it was getting ported to the math and that's the best you can do... (I can dig up the equations if you want them)
Flow Bench's are actually quite terrible measures... in fact Ford use to do that with all their high performance heads they sold for big blocks.. they would keep the highest flowing heads for themselves. Well they found out later that they weren't the most POWERFUL heads... they found they got better dyno results from some of the heads the flowed considerably less air. So they started test stand dynoing all the high performance heads and that way they could keep the best ones for their racing team... so the flow bench lied.
Also then you have to ask if you want a valve installed or a valve out flow reading.. and what about during the different stages of lift? All those things will affect the overall flow of the head and how much throughput it has... so in other words... Flow Bench = useless numbers
Kind of similar to peak horsepower and big turbos etc... you can make a high number... but a lower peak vehicle can still outrun that big one because of more overall area under the curve... again that isn't something you can measure on a flow bench with out a ridiculous amount of effort and logging.
