We also cannot wait to see what type of power it makes. I am thinking around 260-280 at the wheels. Tuning and building cars is only some of what we do. We are also a full service in house performance machine shop. We build performance engines all day long. We can build you or anyone any spec engine.Maz_Speed13 said:wow those pistons look real nice, are you thinking about doing this to other engines for a price or just to yours? maybe worth it if you can get some people who would want a strong engine i would be interested. but can't wait to see what the finished product turns out and what it puts out.
thanks fo rthe updates, keep them coming
Maz_Speed13
You blue the surface and then trace out the gasket. The blue that you see is what is left.CustomMSP said:Do the blue marks on the mani represent the amount of porting that'll be done?
Thanks.
Yes we do all of our machine work and building in house, outside of grinding crankshafts. Years ago we did a lot of regrinding of crankshafts. Now most people get new aftermarket crankshafts if they can. For the Protege and some other crankshafts I have a good friend of mine grind them for me.PaulMP3 said:What kind of rods/pistons are they? What material are those pistons?
Looks really good nick. You build/balance the whole engine in house?
Boost and more boost, the only replacement for displacement. Oliver rods are very good, a little on the high side for most people with street engines. Good luck with your 500hp land rocket.MAMotorsports said:Looks good.We are also building a motor.However we are using Oliver Billet Rods and CP pistons.Our head is getting fully worked.We are looking for 500HP on alot of boost.
Good luck on the project.
We did hit 13.7s @104mph on a stock engine.mazdaspeed75 said:Man i cant wait to see that and cant wait to go forged. Just not anytime soon let the stock stuff take a beating for awhile i guess.
Oliver is the best of the best and you gotta pay to play.Good luck with your setup. I would like to see how it turns out.By the sounds of it we are building close to the same setups.MPNick said:Boost and more boost, the only replacement for displacement. Oliver rods are very good, a little on the high side for most people with street engines. Good luck with your 500hp land rocket.
Thanks again
Later.........Nick
Was that with the mpi tuner . I have a guy here that runs a 13.9 on drags and claims to have only gutted cats greddy e-01 at 9psi thats it .MPNick said:We did hit 13.7s @104mph on a stock engine.
Thanks again
Later........Nick
Engine builders would debate who has the strongest rod along with many other things as to what is better. I will leave it at that. For 500 hp I could see you wanting to go with Oliver rods, they have worked good for you in the past. I would go with the Manley Pro Rod. Again both are great rods but one builder may have had better luck with one over the other. Not saying that one is better then the next.MAMotorsports said:Oliver is the best of the best and you gotta pay to play.Good luck with your setup. I would like to see how it turns out.By the sounds of it we are building close to the same setups.
Thanks,
Beau
I agree.Opinions are Opinions and just that.Yes, the gear box does have some concern.We are going to have the gears cryo treated.If that doesn't work, then I will get on the machines and try and build our own set.MPNick said:Engine builders would debate who has the strongest rod along with many other things as to what is better. I will leave it at that. For 500 hp I could see you wanting to go with Oliver rods, they have worked good for you in the past. I would go with the Manley Pro Rod. Again both are great rods but one builder may have had better luck with one over the other. Not saying that one is better then the next.
Yes we are both building sound engines but I think you may have a problem with a stock gear box before me. All that power may suck when it comes to axle and gear boxes.
Thanks again
Later........Nick
Yes we use the MPI Tuner. I have seen people post more then a few times on this forum. It always seems that when people do get to the track to see a car run the story is never the same.mazdaspeed75 said:Was that with the mpi tuner . I have a guy here that runs a 13.9 on drags and claims to have only gutted cats greddy e-01 at 9psi thats it .
