boostisgood said:Hrrrm, I am installing my Greddy this weekend.(as long as Spool sends me a flange.) I will try to tap a vac line directly from the head, to the BOV. I had my questions about so many (more then 1) things running off that same line.
You can run as many as you like off the manifold but i'd only use the boost controller to the dedicated line for the wastegate. I've found putting the stock BPV to the source of the intake manifold helps alot with boost lag and spiking.
-Alan
