I did a search and found out some recommendations that people recieved. I do not need a lot of bass but would like a little more than what the msp has.I also do not know much about car audio. I work at Best Buy so I can get a good deal on car audio stuff.
I want to keep the stock box. I read that the JL8w6vD2 fits into the stock location, is this right? Is there another sub that will fit there?
If I just wanted more bass then could I rewire the sub with 4 ohm wire instead of 8 ohm and flip over the amp? Will that blow the stock kenwood sub? Also what is required to flip the sub over? Any special screws, brackets, etc. needed?
