MSP rotors on P5
but will they bolt right up, nothing extra to do or anything? I need different rotors(warpage) and am trying to keep the cost down due to other mods. Used from MSP to P5?
fellas you need to use the MSP calipers and Rotors, i get the calipers for $80 each ($35 less if you have a core MSP caliper) the whole kit runs $350 with cross drilled and slotted rotors, it made a big diff. in the braking
is the $350 the total pricee for the brake job or no. cause im either thinking to get new brake pads such as hawk pads or just doing the front with rotors and pads. i dont think adding new rotors and pads to the rear will change much. did u change your rears 2 or no.
yea no it is $350 for the fronts (where most of the braking is done) pads are $38 for the axxis or you can use your own, on the rears i just left it stock
that's coo, maybe i will consider it later on. i just spent another $220 on my car with just an intake. vividracing.com has the k and n typhoon intake for $209.
any chance you can get those as well? I've still got at least 50% all around, but as soon as my pads wear out, I'm definately coming to you for your kit.
