MSPDetroit
- 03 MSP Black Mica
Well boyz the Speed is in hibernation for the next 3 months. just put it in the garage today. should be back out in march or so.
oliver2000 said:
Put a small chalk mark on the tires and do not park the car with the tires in the same spot ( try to prevent flat spots )
BMC said:You can also put pieces of thick carpet under the tires, or at least thats what I do.
MSPDetroit said:Damn!!!! all i did was top the tank off and park on four pieces of wood. haven't had the chance to wash it cuz the wether is soo bad its been raining for like a month straight and it just recently snowed. so i'ma have to wait a little till its clear and theres some sun. what does leaving the window open prevent?? oh yeah, i suspended my insurance as well. Big Money Saver!!
MazdaDryvr said:I thought about doing that, but I'd miss my speed too much.![]()
MSPDetroit said:oh yeah for sure... fire, and theft is still on there. what kind of fuel stabilzer?? u can get that at autozone right??
Well folks it's spring !!!.....being behind the wheel again sure makes you appreciate the car again just like they are new...so for those interested here is what I did to bring the cars out of storage.oliver2000 said:Our Mp3 and Msp are in storage and have been since end Mid Nov...
What did you do to " store " the car....
Here is what I did...
Hooked up a solar charger to the battery to keep in fresh and not get killed by off-key drain ( clocks, alarm etc )
Lowered the tire pressure to 25 PSI
Opened a window 1/8 of a inch
Stuffed a old tshirt in the exhast pipe ( prevents rodents living in your exhaust plus moisture )
Covered the CAI and intake on the msp ( essentially sealing the air intakes )
Changed the oil and filter
Put fuel stabilzer in and topped the tanks full
Covered the cars with a good quality car cover
Washed and waxed the cars , cleaned the inside
Parked in reverse gear and no parking brake ( prevents the pads from sticking )
Only thing I did not do was fog the engine with storage spray ( like I do for the boat engine )
I start the cars once a month and let them warm up fully, a drive around the block if possible ( aka no snow )
