msp help!!!!!
lol welcome to the protege family
and thats normal, there really isnt anyway to get rid of it unless you buy a Piggyback called the Splitsecond Air/fuel controller
whats happening is fuel cut, search it and youll find alot of s*** out about it
Unichip would also be a possibility if it's normal fuel cut under light loads.
If it's not I think this might be a failing WGA causing overboost in term causing the ECU to go into failsafe mode (fuel cut) Check that before turning to piggyback engine management
