MSP bad bearing noise turned out to be Axel shaft bearing
HCFL
2003.5 Mazdaspeed Protege Blazing Yellow
So here's my situation. One bearing was bad and has been changed.
The mechanic who did the bearing told me that the other side was not a bad bearing, but a bad intermediate shaft bearing. I assume this is the same as an Axel shaft bearing. If so, am I able to just get one of these bad boys from rockauto and install it myself or would it have to be pressed like a wheel bearing.
Reason I ask is because the mechanic quoted me 435 for the part (A brand new intermediate shaft) and 4 hours labour x 135/hr.
If you can get the whole shaft just do that and a transmission axle seal too. You could prob pull it out and replace in like an hour...depends how rusty your pass side hub bolts are as it has to come off. 4 hours for a trained mechanic seems alittle rediculous. I have no comment on part cost though.
Where can I find the intermediate shaft? I cannot find it on rock auto. I'd rather not spend $450 on a new one either. Better yet, if I go to a scrap yard and take one off any 00-03 Protg or Protege5 is it the same shaft?
The shaft should be the same in a regular pro, only the CV axles were larger on the MSP.
Just got the MSP back from the mechanic. Sound is 95% gone. He talked about the bad axel bearing but I can't hear anything. He said that when they put their pipe up to the intermediate shaft (I'm guessing it's a metal tube they hold up to the axel to hear noises) they could hear the bearing.
Either way, I think I'll leave it alone until it makes a huge difference. Next thing on the to-do list is a wheel alignment, mine is way out.
Thanks guys!
