good post all...my sub just died and im tyrin to find a sutable replacement. i miss read i think, which amp is a rated higher then the stok one..but fits in the stock mount?
Well the thing is you probb shouldnt use the stock power and neg. The stock wiring is like 16 gauge, so it blows. I just went out and got the walmart 4 gauge? scoshe wiring kit for like 35 bucks, and its working fine,
I redid the wiring for the amp and sub and replaced the sub with an 8" kicker I had and even with the stock amp it sounds a lot better than before. I think it is plenty of bass but could see upgrading the amp and sub in the future.
I'm just wondering if you guys know the size of the 4 bolts that hold up the enclosure, when I bought mine it didn't come with any bolts. Thanks in advance!
I just replaced the sub in my car tonight with this Kicker. Fits perfect but the stock shroud for the sub won't be going back on and I had to cut off the factory MSP connectors and just run plain wire to the sub.
