haha wow didnt even think of splitting it with a Y...good idea. well like i said ill post up some pics once i get it done which wont be for a few weeks im waiting on a bunch of stuff from SU to come in then ill do it all at once.
Well ive used Meth on my lightning... the nozzle goes right after the MAF... squirts the meth into the t-body, through the intercooler, into the blower, into the intake... Same with my nitrous setup. Are you saying im going to have an issue on the MS3 because that air is going into the turbo, through the intercooler, to the tbody?
Now, where the fruck is the Tbody at? Is it after the intercooler pipe at the back of the motor? I cant tune it since the PNP adapter isnt available yet, but i think the MS3 will make good power with it until its tuned. It will get colder air and more octane. I figured someone here has done it on their MS6, so i was seeking advice where your nozzle went.I think if we all put out heads together, we can get this to work really well.
Now you've got the intercooler in your way. So you want to inject it post intercooler.
The TB is right in front as you're staring at the car, behind the radiator. You will see it as the cold pipe from intercoooler feeds into it.
I think you're gonna have a problem with running the car until you can tune it. As you will probably need to remove some of the fuel from the stock tune. But maybe you might be lucky.
Expect to see your A/F reaaaaaly richen up upon meth injection.....I think CPE is working on a Meth controller?
yeah, they are designing a meth injection kit.... I'm hoping for some good details before the end of the summer! They might have to make it use a stand alone controller for now, but maybe the Gen2 standback will have the controller functionality there as well - to consolidate things a little bit!
Couple of important things:
1. You need to place it pre-throttle body
2. You need to lean out the fuel when using meth
3. You need a progressive controller or it will bog
Tons of info on the Evo forums about this
I agree with all of the above points, but would like to add some further remarks based on my experience with alcohol/water injection on my MSP and my research on the subject.
1. The general rule-of-thumb seems to be to place the nozzle after the intercooler on a turbo set up, after the MAF, and as close to the throttle body as possible. This is how I have my system installed.
2. If you are spraying 100% methanol the A/F ratio will indeed fall, so you should have a means to pull gasoline. When spraying a 50/50 mix of denatured alcohol and distilled water, my A/F ratio did not change appreciably, but that could just be my car. This information is dyno verified. I cannot speak to the effect of other alcohol/water mixes on my A/F ratio.
3. You can still bog with a progressive controller if you have the min and max buttons close and run 100% duty cycle on the pump with a sufficiently large nozzleI know because I did (I tried to do it on purpose for testing). The progressive controller allows one a rather large range of adjustment (at least the Coolingmist product that I have does) so that the bog can be eliminated.
4. Spraying alcohol/water without a tune designed for it will not, in general, yield significant horsepower and torque gainsit might if you had significant detonation beforehand and the alcohol/water injection eliminated it. In my case alcohol/water injection netted me only a few additional ponies without tuning for it. Once tuned for the additional alcohol/water, however, the car responds like never before!
Again, I would like to point out that these comments are based on my experience with my MSP and rather extensive research on the subject of alcohol/water injection.
I figured there has to be one of you MS6 guys with a methanol kit!!
