MS3 wheel question.
Hot Shot
2007 MazdaSpeed3
Hey Guy's,
I found a set of rims I like for my car, but wanted to make sure the centerbore will work.
5x114.3 18x8.0 +48et centerbore 64.1
Tirerack has 18x8 with a +48 offset, but nothing listed for centerbore......
Any help is appreciated.
James
it will work fine
that's about what I am running and I am lowered with no rubbing at all.
OK rather than start another thread, I thought I'd ask here. Anyone know wht weight of the stock MS3 wheel?
I looked into getting some rims that had a centerbore of 64.1 mm and the guy I talked to said it could be machined to 67.1 mm without compromising the strength of the wheel.
It could be, but does it have to be?
He led me to believe the centerbore needed to match up. Hopefully someone that knows definitively can answer.
no it wont fit, a 64.1mm hole wont fit over a 67.1mm object.
(rofl)
yes you can bore it out, no i personally wouldnt do it.
Read this, yes its long and theres a couple of cat fights but theres also some good info.
(delete gaps at each side of 3)
http://www.mazda 3 forums.com/index.php?topic=64204.0
good luck
