Ms3 video clunk
Check the 3 mounting bolts for the strut in the engine bay as well as the top nut that holds the hat on.
If it's none of those then I'd check the end link and the bolt that secures the lower portion of the strut.
Just heard back from Mazda Tech. He said there's a TSB on the subframe bushings for 3's and MS3's which is probably the case. I'm thinking that might be it as not only can i hear the clunk but I can feel it under my feet going over bumps...as if something is bumping up against the floor board. Thank you for the info. I will check those as well.
