MS CAI to SRI?
i ran injen cai as sri right now just for winter ....nothing really change but it is easier to change the filter......i probably put in CAI again cuz summer is coming i do not want hot air going to the turbo.....
I am running it in SRI with the straightener, just put the straightener in and then the filter. Have been running it since October.
So I assume it is running fine then. I think I'll make the switch tomorrow. Does it sound different as a SRI?
Yeah its pretty loud as a SRI. and Yes runs great. LTFT are -3 at idle. 0 at light throttle and 2.6 at WOT
Why are you switching? Are you having trouble with your fuel trims
in SRI mode. the sucking sound is much quieter than CAI due to less piping for the air to rush through. throttle response seems to be much more crisp and the BOv sound is more pronounced. in CAI mode, the air being shot back into the intake(recirc.) kinda over powers the BOV sound since its not as crisp as in SRI mode. the recirc.ed air being shot back into CAI is a bit longer and drawn out.
performance wise. as i have said in another thread, i did highway rolls in CAI and SRI mode against my boy in his MS3 with the CP-E Nano and Turbosmart BOV(i have a Greddy Type S so we are equally modded...)
myself running in CAI mode and him in SRI. up until about 110-115, our cars were dead the whole way but after that i would began to pull on him on the top end...EVERYTIME. we did atleast 6 runs.
when i switched SRI mode, him still in SRI. we were dead even the whole way, even in the top end. we did 6 runs this time as well.
so on the top end in SRI mode you will lose some power. but the benefits in why i have kept mine in SRI mode is because you can hear your turbo spool if your BOV/BPV is tweaked right...the Turbo has that high pitch sream/whistle/shrill sound versus CAI, its all intake sucking sounds.
SRI has crisper throttle response and your bov/bpv sounds better(louder)
but ill be switching back to CAI mode today and leaving it for another few months. i go back and forth between the two every few months
I think I will end up doing the same, and go back and forth between the two. I had an Injen CAI before and I definitely felt power loss going to the MS CAI but I did it to have no issues at the dealer. Also a big difference was the sound my Forge BPV made. It got a lot quieter with the MS CAI.
So there are no clearance issues with using it as a SRI? I have the MSCAI as well. I guess you just remove the lower pipe and attach the filter directly onto the upper pipe? I may try this because my fuel trims are higher than I would like. Maybe this will help with the turbulance.
the filter will rest on the frame of the car. atleast mine does. so i have to put the filter on in a slight angle since the maf pipe is a bit long. but it provides support.
So I just did this and have a couple questions.
How far did you guys put the filter on? Did it cover the Mazdaspeed logo?
It seems like a tight fit and am not sure how far I should put the filter on.
