Yea, you like hearing the turbo and BPV so you are on the gas more.
Do you guys think that the MS CAI can cause the car to burn more gas than without it?
Thanks for your replies.
How does power equate to fuel usage? It is creating power from better air flow. CAI does not cause more fuel usage does it?
I was under the impression that the original idea of CAI's were for fuel efficiency gains.
have you guys noticed reduced gas mileage with the CAI installed? My car is only a year old, but i've noticed poor gas mileage in the past months.
More power generally involves burning more fuel. You can do a few things to improve power: you can burn more fuel, more efficiently burn the fuel you have available, or decrease mechanical resistance and thus mechanical power loss (think lightweight pulleys). Our turbo essentially allows us to burn more fuel by providing more air (oxygen) with which to burn more fuel.How does power equate to fuel usage? It is creating power from better air flow. CAI does not cause more fuel usage does it?
So how does an intake provide more power? Two ways. You get colder (and thus more dense) air, which again means we can burn more fuel. It also allows air to move more freely. The motor works less to suck in the same volume of (now more dense) air, as there is less in the way to restrict air flow. This is why an SRI or a CAI provide such similar power gains on our car - Cobb tuning called our stock air box one of the most restrictive they have ever seen.
We have motors that run pretty rich stock. There is a lot of extra fuel in the cylinder each cycle, and we don't burn it all. An intake should provide more air (colder, more dense air) so we can burn more of it which produces more power, and allows air to flow more freely so we lose less power pulling in air.
All of this adds up to a more efficient engine. You make better use of the fuel you have available, you lose less power due to air restriction.
my mpg's went up by 3mpg after installing the ms cai.
