MRLILGUY/PG fuel pump installed !
Cool
I got the replacement pump a couple days ago and it seems to work perfectly. I havent done much datalogging with it yet but i did just get my wideband put in. before with the stock pump at wide open i was around 11-11.5. now its reading 10 flat so its obviously pumping more fuel. now i just need to fine tune it again and i'll be all set.
Good work to mrlilguy on the pump.
When you have some data please share with. Sounds like it is working!
My pump just came in Thursday. I'll be installing it today before I head off to work. Would like to see how it does with my mods. Did you guys pop off the gas cap, remove the fuse and relay, and try and start the car to relieve fuel pressure?
data
I guess with the wide band you already have shown that more fuel is supplied and, to have to pare it down is a good thing. Thanks speedy
