mr.Speed Sc kit for the FS
It looks like it's going to be a close fit wih the exhaust runners. I'd lke to see a picture of it with headers installed.
I would totally go for the megasquirt.We can only use that for fuel right now right, the coil packs are hard to work apparently.
"Mr.Speed will soon have its four-cylinder Supercharger kit ready for the public!
From Initial plans and work, the design and application has changed considerably. The kit now utilizes a Clutched Eaton M62 blower, just like our V6 Supercharger kit.
The will come in two versions, intercooled and non - both of which at 7psi of boost.
The non-intercooled kit comes complete with all mounting hardware, intake pipes, couplers, t-bolt clamps, vac wiring, switch for the blower, two blow off valves and instructions. The Intercooled kit has all of those items, plus the intercooler.
An upgraded aluminum crank pulley will be an option, this will allow higher boost levels while keeping the clutched feature of the supercharger. Pulleys are anticipated to come in sizes to compensate for 9psi, 12psi and 15psi."
no 1.6L love (argh)
did our engine get put in anything but the BJ chassis ????
TampaSport20 said:
no 1.6L love (argh)
Is it a 1.6 BP?
European miata????
Otherwise you'll have learn to weld and DIY...
