Also if you look in the manual it tells you exactly what Nick is telling you.MPNick said:If you have -7 it means you are now -7 degrees of timing over the stock curve at that map point.
Thanks again
Later...........Nick
Thanks again
No, no i don't.Little Beavis said:Have you NOTHING better to do?
LinuxRacr said:I notice at 1-2 PSI dialed in with the MPI Tuner, I was pulling like when I was 6 PSI before the MPI Tuner. (eekdance)
I call mine the UFO under the hood.Little Beavis said:Yep, definitely works better. . .but I would say that would be any "decent" fuel control above a FMU or RRFPR or whatever you want to call it.
(lol)StuttersC said:I call mine the UFO under the hood.
As far as the gas goes, I am really not too sure...You will probably just have to tune a tiny bit differently for the lower octane, and load that map when you are going to be running that gas.Matthew said:will this tuner allow you to run the same boost level regardless of whether 93 octane is available as opposed to 91 (as in CA when i live there for a year) and if you could run it the same boost level at say 4600ft above sea level and 900ft above sea level (difference between ft. sill, ok and ft. huachuca, az)?
Matthew said:so these maps save right to the hard drive? so you could have say a map for better emissions, a map for track use (pushing the car close to the limit), and a daily driver map? sounds great. im just PEEVED to have my speed capabilities dictated by some morons who decided after supply and demand that 93 octane wasnt necessary in CA and also that just because im living in sierra vista arizona for four months means i cant race as much due to only being able to boost 6psi
this is my reason for wanting the tuner so bad. until i go forged and get a new clutch, i just want to be able to boost 8psi no matter where i live or if 93 or 91 is available. im picky like that.
Matthew said:so when you talk about the MAP and MAF in your last paragraph are you saying that with the tuner the elevation will not make a difference? so that problem is a complete non-issue? if so cool, if not please explain a bit more.
Matthew said:are there any pics in these million replies of the setup and where it plugs in and all that good s***?
thanks. thats what i like to hear about the fuel and the altitude. now i just need to conquer the emissions sticker and do some shady s*** to get my car inspected when i move to AZ and then to CA for a year. i found out ill have to get emissions tested to get a sticker to get on post there. here you dont.505zoom said:The maps will save into your MPI folder... mine is in the C drive. You go into file and then load map, and your desired map is then loaded. I only have 91 octane fuel here, and I have been tuning fine using it.
I run my car at 5500ft most of the time here at school, and then go up to 7200ft when I visit my mom. I haven't noticed any ill effects using the maf.
I have some pics in a couple of other threads and on my cardomain page. "MPI tuner up and running" in this section, and "MSP getting some more upgrades" in the MSP section.
Matthew said:thanks. thats what i like to hear about the fuel and the altitude. now i just need to conquer the emissions sticker and do some shady s*** to get my car inspected when i move to AZ and then to CA for a year. i found out ill have to get emissions tested to get a sticker to get on post there. here you dont.
While I do have only 1 high flow cat. . .I don't have emission testing in my area (just outside the "Chicago area" for that).acidbbg said:Little Beavis..passed and he is only running 1 high flow cat..
