MPI got gear.
but ithink its fast enough lol
you're really close to redline in 5th at that speed =\
you can overide some of the stock settings ? is it full standalone ?
i wana get rid of the rev limiter ... one day
the haltech? ENTIRELY controls fuel and ignition. the ONLY thing the ecu does is show my RPMs, temp, basically just runs the little s***- dome lights, tach, gauges, etc.
with a standalone I dont see why it couldnt.
137 for me I know I stil had some rpm left to work with...
Top speed depends on the overall diameter of your tires, since that's your final gear; Smaller diameter, shorter gears, lower top end. Larger diameter, taller gears, higher top end. That being said, everything stock, the theoretical top speed, not inclusive of drag coefficient, of the Protege5 (195/50R16) is 144mph with the stock gearing. Those who push a lot of power should be able to go about that fast. But I do mean a LOT.
pdhaudio83 said:
you guys are ecu speed limited? damn. teh suck.
it's not about being speed limited, it's about cruising at 70mph at 3.5k rpm. I hate that. if we could cruise at that speed at like 2.8-3.0k, it'd be great
I personally think that 1's & 2nd gear..are what need to be replace...that would or should rather..remedy the notchiness..and permit better shifting...5th gear would be nice as well.
Why didn't this thread ever really finish?
Where MPNick nowadays, what happened to this tranny stuff?!?!
I have my tranny struff. Anyone interested give nick a call or a pm.
ddogg777 said:
To educate those who want to know, here is a copy/paste:
"[font=Verdana, Arial, Helvetica, sans-serif]Spur gears have straight teeth and are used to contact parallel shafts. Spur gears have a high pitch whinning noise associated with them similar to the noise reverse gear generates.[/font] [font=Verdana, Arial, Helvetica, sans-serif]Helical gears are used in standard factory transmissions. The teeth on Helical Gears lie along a helix, the angle of the helix being the angle between the helix and the pitch cylinder element parallel with the gear shaft. Helical gears can connect either parallel or nonparallel nonintersecting shafts. Such gears are stronger and quieter than spur gears because the contact between mating teeth increases more gradually and more teeth are in contact at a given time. [/font]
[font=Verdana, Arial, Helvetica, sans-serif]Helical gears have one disadvantage when compared to spur gears. When they are loaded a side thrust is created that must be absorbed in the bearings."[/font]
great info!
I remember Focus making a post but I cant find it now :( the prices were in there
