Mp5t
Status
Not open for further replies.
I can get at it from anywhere. The dash is empty.
The HVAC pulls out
The Glove Box Pulls out
Brian, just out of stupid curiosity how or what are you using to vent the crank case?
And here I was thinking it was more elaborate. I take it you don't pipe in back into the intake and such?
Nope... As I see it... Positive Crankcase Ventilator... Which means that the pressure is always escaping or leaking out... So why would I want that anywhere but out of my engine and engine bay.
Both vents on the valve cover, have a hose that bends towards the road, by the transmission and hang just below the oil pan level.. The two return nipples on the intaka manifold were drilled, tapped and then a set screw was used to plug the hole with thread lock.
interesting, my hose from the pcv to the intake likes to come off and makes my car run like poo.
edit: the hose being off could cause a leak in the intake mani which is making the car run like poo and not really the pcv- just a thought.
will the dash go back in or is it staying out for good?
Your edit is correct.
and yes it's all going back in
I gotta say thanks again for the write up on the Haltech as I have an E6X I will be installing.
1/8" MDF was flimsy but light and the foam is UBER stickey so I decided to cut out the shape in MDF and then use the foam to glue it to the firewall. It is Rock Solid.
Not "FOOSE" level or quality, but it's out of the way, light weight and most important, easy to access. The dash is held in with 8 Bolts so if I really need to get at everything, it can come out quick.
No
I have a Garage, and cars are waterproof.
Even if there was humidity, Ontario isn't humid in the summer like NB
I drive my car regardless of weather, so if it's raining I will drive it
I am not worried about anything ******* up on the firewall
It will not get wet there.
Remember, I don't even have wipers on my car. Lol Wet MDF is the least of my worries
No
makes sense, yea i miss the dry heat of Ontario compared to here. Is your engine bay already resprayed?
Wideband O2 #1
Wideband O2 #2
Wideband O2 #3
Water Pump
Fans
Boost Controller
Oil Pressure
Fuel Pressure
Oil Temperature
RA-10
(On a separate harness)
Injectors
Ignition
TPS
CTS
IAT
IDLE
brian, i must have missed something...you just did all this what yr or two ago? i followed your thread when your ripped the car apart...you're doing it again? i know you were doing the mani...
Status
