- MP5T / 944
The motor is balanced and built for 8500 RPM with the Rev Limit removed. However, I'm shifting between 6500 and 7000 with the shift light coming on at 6500... I'll save the silly pull of high RPM for 15 Psi on a "Track Day" or Dyno...
Focus said:How did you remove the rev limit ?
daedalus said:are you running upgrade valvetrain?
TurfBurn said:Nice little system! Pretty penny I'm sure?
daedalus said:so theoritically, the valvetrain in our cars is good for 8500 rpm if the rev limiter was removed?
TurfBurn said:If you'll dish on the reinforcements that'd be cool... but no worries if that's a "trade secret" too.
not a bad cost for the system... roughly 1600 american then.... Lots of bells and whistles... the installation and how it does with our sensors and the like will be interesting too.
batmang said:i wouldnt go passed 7k if the top and bottom end are stock.
id be quite scared to even go to 7k.![]()
Brian MP5T said:I have a Bud with a Subaru RS WRX who is running it and I was talking with the Installer. It's totally compatible and the fact that it runs on a MPA is very desireable..
BlkZoomZoom said:You really think you'll be making power above 6.5k? I think a set of cams would be necessary to make power up there.
