If your P5 is going through a lot of low beam bulbs it's because the spring clip that holds them in has been deformed and is not holding them in place firmly. This allows the bulbs to vibrate on rough roads or when crossing something like RR tracks. Vibrating a bulb with a hot filament creates instant burnout. (If you are using Sylvania Silverstars, the problem is even worse because of their short lifespan).
The spring clip is easily deformed if you press down to hard when trying to release the clip. Easy to do because the clip is in an awkward location that makes it difficult to move them laterally off the hook. The clips can also be deformed when trying to unplug the wiring harness if you don't hold the bulb receptacle in place while pulling on the plug. But his is why burnouts seem to happen more often after replacing the OEM's.
To test to see if this is your problem, unplug the wiring harness and remove the dust boot, leave the bulb and spring clip in place. With the tip of your index finger lightly try to wiggle the bulb contacts from side-to side and up and down. If there is any movement at all, your clip is deformed.
To fix it you have to remove the clip and re-bend it so both sides of the clip evenly contact the back of the bulb receptacle when the end of the clip is still about 1/4" away from the hook. This is best done with two persons unless you are really good at working while looking in a mirror. A lady friend with small hands makes an excellent assistant. Make sure you have a good hold on the clip when you loosen the screw on the "hinge side" (you only have to loosen it, not take it all the way out, in order to slip the clip out). Otherwise it can fall into to pretty inaccessible places (personal experience).
This takes a little trial and error to get it right, but you’ll know when it’s right the instant you perform the wiggle test.
Whoever thought this retaining system was a good idea should have their head examined.
Whoever designs a bolt-on alternative will make some money.
