MP3 - Racing Beat exhaust review
Nomad
Contributor
MP3/Racing Beat exhaust review for P5
So I got a rear section Racing Beat exhaust (oval tip) from an MP3 to put on my P5.
The exhaust, like others know, must have the tip shortened about 4-5 inches since the MP3 is a sedan. Mine was already modified (thanks to "Mad Hatter")
I rolled the rear of the P5 onto ramps and had plenty of room to work. I soaked the exhaust bolts with "PB Blaster" penetrating spray the night before and again before i started working. I scrape as much rust build up off the flange and nuts as possible. I then tapped a 6 sided 14mm socket onto the nut. (don't use a 12 point wrench or socket as these bolts will strip)
I slipped a 12" length of pipe onto the end of my ratchet and with a few grunts both bolts eased off. If they won't move you could try a small propant torch to heat up the bolt. Or as a last resort you could cut off the stock bolt with a sawzall (the Racing Beat rear section should have the two bolts attached to it)
The stocker slipped out of the hangers easily and the racing beat went in easily and lined up perfectly of course.
I had an exhaust flange gasket laying around so I used it, you could reuse the stock one if it's ok or go buy a new one if you want to be sure there are no leaks.
I got a tube of some high temp silicone RTV (in the red or copper tube). I put a good bead of this on both sides of the gasket.
I used high temp Copper Anti Seize liberally on the exhaust bolts. Hopefully this will make it easier if I have to go back to stock. I tightened everything up and let it sit overnight.
No leaks, slight sound increase and it looks nice. A classy look, very subtle.
The sound is only slightly louder than stock. It was hard to tell a difference at idle and parked revving. I have stock intake and headers/cats. At speed I can tell there is a little more sound behind me. Usually the P5 has a little sound coming from the engine and intake when driving. Now the sound could be described as even front to back. At 3500 rpm cruising it is in it's more resonant range. To the average joe they wouldn't be able to tell from inside the car. This is good as I wanted just a little more noise with zero resonant booming or attention. (I've already gone down that road in the past, got it out of my system)
This is a very mellow change in sound. I can see if some kids might want a loud aggressive exhast, this won't do it unless you delete resonators, cats or change headers etc.
I'm pleased with the results.(thumb)
Do you have a picture? I thought the MP3s came with the same round tip as the 03 MSPs. Only the 03.5 MSPs had the oval tip.
It's oval, I just looked at it. The tip flares out right to left and it is angle cut with a rolled edge. I'll have photos in the future.
I just put on the MSP 2003.5 axle back yesterday...its oval. Oh and I love the sound...is it possible to fall in love with a car twice?!?!?
as far as I know, Racing Beat doesn't sell the axle back seperately. You have to get the whole cat-back.
This was the rear only from an MP3. It has Racing Beat logo lasered on the side.
It's got a nice deeper tone than my Miata and is not too noticable from the inside of the car. It thought it was really quiet at first but it's because I'm used to driving my Miata with Jackson Racing cat back and intake. There's a lot more noise in such a small convertible. When I'm standing outside the P5 it sounds nice driving by so it's not as "silent" as I first thought.
I love the sound of mine as well, nice deep tone to it. It also looks like it belongs on the car, and isn't tacked on.
I was searching for some advise on my exhaust and saw this. I also have one from a MP3 and love it. The sound is exactly what I was going for, and is not obnoxious at all (a big plus.)
There was a recent snow storm here over the weekend and I noticed some rust building on the inside of the exhaust. Do you sand the rust off, and if so what type of paper?
If you ever saw my thread of the one I recieved with what looked to be rust but was only corroded from going through winters up north, I cleaned it all up with just some mother's mag & aluminum polish with a towel. The same should work for the inside of the exhaust also since I had some corrosion also going on inside the piping and cleaned out all of what I could reach.
http://www.msprotege.com/forum/showthread.php?t=123616651
Sweet, thanks for the advice! I'll have to try that this weekend.
MP3 Racing Beat muffler has the "squished" oval tip, while the MSP is more of a rounded oval. Here's my Mazdaspeed / Racing Beat.
Are you sure? I think the MSP tip looks more like a squished oval than the MP3.
Pic#1 MP3
Pic#2 MSP
aMaff said:
I THINK that 03 msp's had a round tip
Yep, same tip as the MP3.
